Swim platform shower - cover broke - Heater Craft Marine 2005
BriteEyesBriteEyes Member Posts: 18 ✭✭
Has anyone ever replaced the cover and if so where did you buy it?  I've searched and reached out to Heater Craft (2 times but no response)
    Try this.
    http://www.replacementboatparts.com/
    AquaTik transom shower door
    Image gallery
    Next >
    In Stock
    $17.99
    Quantity
    AquaTik Transom Shower door
    Frenchship, good find. Any idea what this part is for? I had one over my sprayer end but it popped off overboard when I turned the shower on and I didn't care because I couldn't see the point of it. What does this do?
    This hold the shower head handle into the compartment.
  • Cableguy GregCableguy Greg Member Posts: 5,078 ✭✭✭✭✭
    The hold for my sprayer was so tight, and kept popping off the screw, I cut a few notches in it to help release the sprayer.
    I see, just to hold it in the box, thanks. Not sure this is worth replacing. Will have a look. Kinda sits in there anyway.
    Mine came off several times too.never thought of notching it great idea.when it's wet it slides right in,then dries and sticks.I put some lube on it and it help.but the tread is about the door.
    Here is what I did...
    I haven't had a problem since.
