Raw water strainer installed wrong
Fired up motors today,trouble getting port motor to prime(impeller changed last year).cleaned out strainer and the yuk was under the basket? The thru hull and the outdrive Y together and enter the strainer in the lower hole and the pump exits above the basket.I assume this is a factory install.Did not take pic's as this just sunk in after looking on the web.
notice the arrow,I think mine is backwards?
Is this the same unit you guys have?
2005 342 5.7 horizon
2005 Rinker FV342 Pawcatuck river,Ct
Best Answers
reneechris14 Member Posts: 3,134 ✭✭✭✭✭
I'll climb back in tomorrow and check again.
This a factory install?2005 Rinker FV342 Pawcatuck river,Ct -
craigswardmtb Member Posts: 1,015 ✭✭✭
Mine have given me trouble priming in the past as well. A quick bump into gear and some throttle has always gotten the water flowing. Note I do not have a thru hull pickup. Just the drives on the 496s/360fv. -
Liberty44140 Member Posts: 4,412 ✭✭✭✭✭
I have the same setup but not sure on direction, I can look at it next weekend07' Cruisers 390 (Previous Rinker's: 06' 342EC & 01' 310FV) -
rasbury Member Posts: 8,485 ✭✭✭✭✭
I have a thru hull pickup and will also check but can't imagine which way it flows through would matter...
