Jabsco toilet
chamberb
Member Posts: 265 ✭✭✭
I need to buy a joker valve. I cannot locate a model number anywhere on this head. Any ideas what model this is? It is in a 2008 260EC. Thanks!
This looks like the toilet:
https://www.amazon.com/JABSCO-Jabsco-Manually-Operated-Marine/dp/B00FVY6KEA/ref=sr_1_16?ie=UTF8&qid=1493321122&sr=8-16&keywords=jabsco+toilets+manual
... and this looks like the Joker Valve:
https://www.amazon.com/29092-1000-Jabsco-Marine-Toilet-Joker/dp/B004KKDNNM
You got it! Glad to help. I have one sitting in my boat right now that needs to be put on.
It looks like this is a yearly job. They don't last too long. I converted my old Bayliner to a Jabsco Electric Head which is great until it decides to not work. I am keeping my Rinker manual for now to see how it goes. It's much easier to fix but not as easy to flush.
was gonna replace my jabsco with electric flush
might just do it later in the season or next spring
current jabsco stopped leaking fresh water lol
If you get the Jabsco electric flush kit, it's an easy change to do. Basically you will pull out your manual pump out stack, and replace it with the electric stack. This is a good idea, as it has a built in macerator, which will prevent blockages anywhere else. Also, make sure you bring 12V directly from the battery. The electric flush needs a lot of amps to run properly.
just replaced my jabsco head
wow
now I see why toilet looked newer but main base was cracked
thru bolts with nuts underneath.
problem is you can't get to underneath lol
so got them cut
removed old head
cleaned it all up
some 4200 around the base
tomorrow will run some screws into the glass instead of bolt and nut.
bad design lol
