2005 Rinker 300, outdrive trim
dropout
Member Posts: 138 ✭✭✭
2005 Rinker 300, Merc 5.0 mpi, Bravo III.
What settings are you guys using while getting on plane and when cruising also when just above idle?
When at no wake speed, I usually have my drives all the way in.
When getting up on plane, all the way in.
Crusing, uncertain, seems like all the way in works with a trim tabs down a little bit.
yes much better mpg. with my drives down at 3800 rpm I get .9 mpg. trim up and the boat picks up about 3 knots more and the mpg moves between 1.0 to 1.1 mpg. ie less load and better speed. thats over 10% improvement on fuel consumption!
