Trim Limit Switch on Bravo 3
My throttle control has the dull trim up and trailer button in one and will only move the drive up when you push the switch all the way in (trailer position). I assume this is the trim limit switch on the drive. Can I just change the switch or do I have to pull the drive and change the wires too?
"Mosi on Dahn" 2003 Fiesta Vee 270
you have adjustment but most of the time they get water in them and that the end
test to make sure you are getting signal at the pump for up and down
reason it works after a small adjustments is because you are scraping some of the corrosion away
end result is to get a new one
Thanks!
Has anyone spliced a trim limit switch in without pulling the drive. I know this is not the ideal way to take care of the problem but I am just trying to get by for a year or two. I was able to find a trim limit switch on ebay for $25 and I have been told by a couple of people that this is doable. I plan on using heat shrink connectors, tubing, and starbrite liquid electrical tape to seal.
Thanks, I think it is worth a try.
Cool, I'm going to give it a try with heat shrink but connectors that I will put some heat shrink tubing over it, and coat everything with liquid electrical tape.
I also saw a youtube video where they drilled a hole in the transom above the waterline to run the wires through, but I don't want to get into that!
