Eisenglass Curtain Storage
Wildboating
Member Posts: 957 ✭✭✭
I am ordering a new top and I want to make sure I have a system in place to protect the panels from day one. @LaRea
I discovered Larea's post on how he manages his, must say it makes sense. I am concerned with the wire ties holding the cloth scratching the panels though. Has anyone else came up with a unique storage plan?
Laying the windows flat on a bed will definitely minimize scratching and creasing, but then you lose use of the bed. I stored mine using custom-made canvas bags, and it worked great. Here's how:
1) Get a 10-foot length of 6" diameter corrugated plastic pipe ($8 at Lowes/Home Depot, normally used to drain rainwater away from your gutters). This pipe will serve as a core around which you will roll your windows. The tube prevents the roll from collapsing and making creases in your windows.
2) Cut the tube into two pieces: one for the windows forward of the radar arch, one for the windows aft of the arch.
3) Cover each tube with cotton sheet or towels secured by cable ties.
4) Roll the windows around the tube -- not too tight.
5) Measure the length and diameter of each bundle, and get a canvas maker to build canvas bags for them. The bag is just a canvas tube, closed on one end with a draw-string at the other end. Bonus: Add a canvas handle along the middle of the bag.
5) Roll the windows around the tube, put the bundle inside the canvas bag, and stow it under a settee or wherever makes sense.
This approach works well because (1) no creases, (2) protected from scratching, 3) easy to them move around, and (4) compact and easy to store. I stored them under the port side settee on my 342.
Instead of canvas bags, you could just wrap the bundle in a bedsheet. The canvas bags were nice because the carrying handles made it easy to move them around. (They didn't cost me a lot because I had a close friend with a canvas business ... your mileage may vary.)
