prop pitch
GMSLITHO
Member Posts: 1,602 ✭✭✭✭
Im in the process of buying a 2003 270 fiesta vee with a 350 merc the outdrive was stolen over the winter. Im replacing with a Bravo 3 sea core I was wondering what pitch prop you could recommend Im thinking of the Hill Marine 4x4 or 4x3 with a 22 pitch .I Called Rinker and emailed for the past week but no answer Thanks Greg
Whatever you do, please report back with exact numbers of gps top speed, rpm and seconds to top speed
A lot of people told me that putting the 383 in there I'd see a gain in performance. I honestly have not seen/felt anything different vs a 350. This leads me to believe a change in prop is also needed, kind of like a car.. you can keep putting more and more HP in it, but if you're using the same stock tires that have exceeded their grip potential 3 upgraded motors ago, well, you aren't going to see much more.
The problem is I can't seem to get results from many people with the 4 x 4 propellers or the 4 x 3...
I don't need to be the fastest on the water, would just like to make sure all the extra gas being burned is used to it's best result!
Not really worried about low speed stuff and docking, coming from a single OMC outdrive this boat is amazing compared to that!
Just want to make sure it's biting the water as much as it can!
