Engine Hatch Motor
DaveG
Member Posts: 23 ✭✭
I have a 2005 Rinker 342. Has any one ever had the engine hatch motor quit on the them? Mine has not given me a problem but I was wonder how would you get engine hatch opened if it quit?
Just thinking out loud!
Hoping not to have this problem, Just wondering?
First step: find two or three large-diameter friends willing to help.
Then: Use screwdriver to remove table mount in center of the engine hatch. Insert arm. Remove pin from top of ram. Remove heavy items from transom locker. Ask large-diameter friends to carefully pull hatch open, noting that if they drop it, very bad things happen.
If it is the boat's first time, you will need to cut a slit in the insulation so you can get your arm through.
2. if you remove the table mount on the engine hatch (likely have to cut thru the insulation) you can reach in and pull the connection pin to disconnect the actuator. Then you'll need a friend to help open it.
The sliding sleeve is on there so the actuator does not rip itself away from the engine hatch mount when retracting...and it goes too far. If/when you ever have to replace it, you can get smart actuators where you can set the stroke limits.
Andy
