Shore power question
I have an '08 320 that has shore power recepticals on the port side stern, which is what I've always used. However, I just switched marinas and have realized using the starboard side recepticals that are midship will be more convenient based on location of dock power. I tried to hook up using the later recepticals but am not getting any power. Are both recepticals live (and this one apparently isn't working), or is there a switch someone I need to flip that I'm unaware of? Thanks in advance.
There are 2 switches. Each shorepower point has a main isolation switch. The port rear will likely be beside your rear bench seat, and the starbaord mid will likely be at the panel.
After that there is a shore power selector switch which can be set to "OFF", "Starboard" or "Port". Put that on the right one, and you'll have 110V to the main 110V breaker.
