moving generator exhaust from side to transom
Mercury2005
Member Posts: 141 ✭✭
This is a pic of the side of our '06 270 generator exhaust, disgusting!! Rinker name/stripes were removed to compound, wax and buff then install new name and stripes.
I am thinking of moving the generator exhaust outlet to the transom and just block off the current outlet.
Will survey the available space this week and put together a plan. Observed the location on the transom will be a little lower than the current outlet so I may need to install a riser to mitigate water back flow. Will probably be more quiet then it is now.
A well as what @randy56 said you would likely also violate marine installation and insurance regulations. Highly do not recommend.
If you still have bad flow you may need a new seawater pump.
The exhaust thru hull: look for a crack as noted. I had one crack before (plastic type). Personally, I would get rid of the exhaust thru-hull with that flapper.
New plugs and clean the spark arrestor too.
