Replacing Blower Hoses
Willhound
Member Posts: 4,228 ✭✭✭✭✭
Blower hoses are ripped in a couple of spots so want to replace them.
This thread https://rinkerboats.vanillaforums.com/discussion/5834/fv-312-blower-vent-hose
shows both intake and exhaust hoses. Mine has none on the intake side, just the covers up top. Should there be?
Also, I'm thinking of using 4" "Big O" pipe (weeping tile). Still flexible but a lot tougher than the flimsy plastic stuff. Any reason why I can't or shouldn't?
http://www.ducting.com/
they dont burn and save you a ton $
One hose goes to blower and then to a vent
then same side hose goes to forward of the engine
two hoses on opposite side will be routed down transom and the other one will be forward again
i tested it personally and they meet government rating. That's why you can use them on a dryer
i did use clamps and zip ties.
That is what I used, I think all in it was less than $40
