Noisy electric head
Stodge
                    Member Posts: 2,738 ✭✭✭✭
                    So I've learned more about the electric head on the boat.  This season started off with the electric motor that ejects the waste making a grinding noise.  So I got some mineral oil and poured it down the bowl.  No help.  I took the motor assembly off the base of the head and there was some stuff (dating back to original owner from the look) wound around the motor shaft.  I cleaned that out and inspected the impeller.  This has a rigid plastic impeller after the metal macerator blade.  Kind of a one stop shopping design.  Anyway, I put it back together and it still makes the grinding sound.  I ran the motor when it was off the base and it seemed OK.  Everything works ok, it's just noisy.
Any thoughts on what else might be the culprit?
I'll look for a rebuild kit.
