Location of shower sump pump 1997 266 VF
I have been reading various posts about location of the shower sump pump. I have looked under stairs and only have forward bilge. In aft cabin, only access under mattress is to rear which provides access to fuel tank sending. When I turn on pump switch in shower seems to have drain on battery but nothing working so have to believe pump is getting power but may be clogged drain OR pump. Trying to follow drain lines difficult even with medicine cabinet removed. I tried putting shop vac suction to drain with no luck.
Any suggestions? I have looked everywhere that any of the threads on the topic that have found suggested.
It should look like this:
I though of that too. If that was the case then water would drain to bilge area. Dry as a bone in there.
i can also tell you mine has been on/off again as far as usable. i don't ever use it so i never fully got to the bottom of it, but i had similar issues back when i cared more - i suspect it was the pump wasn't properly primed. i think i did a bit to properly prime it and it worked for the rest of the season, but haven't cared enough to do that in a number of years now.
the pump looks exactly like the jabsco water pump you'll see in the engine compartment that powers the sink, etc. (might even be same part #) once you find that you might find some helpful info at http://jabscotech.com/
hope that points you in the right direction - good luck!
I'm almost in the same mode as you and is WAY down the priority list. I'm one to make sure everything works even if i never use it. I have not tries accessing through the Stb side wall in aft cabin as of yet. one of these days ill get there.
