Alarm System Sounding
Hello All,
I have a quick question which may require a long answer.I have a 2013-2014 260EC. This year after the oil change, water separator change and a few minor preventive maintenance work my alarm now sounds. This alarm will sound extremely loud and it's 1 beep. The warning sign which is on the right side of my steering wheel also appears and then goes away after the alarm, this will happen around every 10mins.
Does anyone have any suggestions before I have to take it into the dealer?
Thank you
Thank you
I believe my boat has to be pulled to check gear lube? I have a volvo penta and the dipstick is on top of the drive. worst design ever
I think @Capt Ron may be onto something with the gear lube level.
Did your tech zero -out your engine oil change hours after the oil change. I had engine alarms and warnings on my V V a few weeks after an oil change. In my case the area Merc rep said the local tech had not re-set the oil hours and the warning was for an oil change.
I know that there can be different settings depending on the program of the V V and its up-dates (mine had the 2016 data up-date) but you might want to check this if the gear lube check does not solve your problem.
