Quick question about using shore water
spalmer114
Member Posts: 29 ✭✭
This may be a dumb question, but I am a new boater and will probably have quite a few of them! lol When I hook my 2001 Rinker 340 FV to shore water, does it bypass what is in my holding tank and everything pulls off of the shore supply? I usually fill my holding tank up all the way, but I would like to lighten the load and only have maybe a third of a tank. I just need to know if I put 15-20 gallons of water in my tank for my time away from the slip and then hook up the shore water for use in the slip, will it drain my tank first?
We have a couple places we like to go that only have lake water so I make a point of traveling with a full water tank.
@Stodge, agreed but I added a second one on both the 2013 EC 310 and 2014 EC 360 on the advice of a friend who owns a plumbing company and a Rinker EC 350.
He felt the add on (we purchased ours at West Marine) was a better quality than most OEM boating units and added extra insurance for a very cheap price. He said he had seen a number of OEM valves fail but never the aftermarket add on ones.
He said installing one before the entry to your boat was a very good idea. I agree as I have personally seen three boats sitting on the bottom at marinas due to water inlet failure.
He recommended the Jabsco in-line Water Pressure Regulator from West Marine Model# 282228 ..... Jabsco part# JABSC#444411-0045. Approximately$40.00. This unit down regulates inlet water pressure from 100p.s.i. to 35 p.s.i.
