Oval window leaking
califco
Member Posts: 59 ✭✭
I started to get water inside the cabin last season through one of the oval windows. I just removed the window, it was a paint to get out. It was leaking at the bottom, I'm wondering if I should remove the metal ring? Boat is in the water and it is difficult to do plus it is going to rain in a few hours. Another issue is the water started to make damage to the wood see pictures, how should I repair the wood? When I put my finger water comes out and the top part is soft.
1)Windshield mounting screws
2)Oval Side windows
3)Vent Hatches
4)Cleats
5)Windshield wiper arm shafts.
6)Bow deck snaps or any snaps
As I have my interior out, I see no leaks from rub rail screws at all.
Then the idea is to spray soapy water everywhere and look for bubbles right?
Here is a video to demonstrate basically the same idea
OK, but what about air leaks from cabin into bilge/engine room? I've got hoses (ie waste, water) that go between the two that I know can't possible be sealed that tight. For my boat, you'd be talking an area of 1500 - 2000 cu feet? I just can't see how you'd pressurize it enough to actually see air bubbles. Heck, I also have A/C that goes from the aft cabin unit up to the cockpit.
