Raymarine MFD gateway for Engine Data
pinkish_panther
Member Posts: 15 ✭
My first post here - likely not my last!
I have a 2008 330EC, I had purchased the Fox Marine Gateways which use MEFI-3 but after I sent them a picture of my "Diags/Depth Finder" connector and the S/N's of my ECM they said my engines are not compatible.
Anyone else done the gateway install to get NEMA 2000 data to a panel from a 2008? What did you use and was it a problem to find the correct connections?
My engine S/N's do not seem to exist! No plate I can find for emmisions and the Flame Arrestor cover label is blank where the Engine S/N is supposed to be. I've sent a request to Rinker to see if they have it on file.
My research indicates my diagnostic port should be 10 pins but I have the one shown in the picture here.
Thanks for reading!
John
Thanks for reading!
John
If it's Mercruiser, you can use their N2K gateway. (Blatant ad: I have one for sale right now.) Do you have DTS (digital throttle and shift)? If yes, you can plug it right into the junction box at the helm. If no, you'd have to install a SmartCraft junction box. Hopefully somebody will chime in with instructions for that.
I'll get a pic next visit to the boat, possibly tomorrow night.
Here's the tag on the cable, it would be great if this is the wrong connector and I just need to locate the correct one - maybe by Fox Marine gateway could still work.
I'll try to remember to post a pic of the final result sometime in July!
In addition to the gateway (because this Rinker does not have a SmartCraft Junction box at the helm) the following additional parts are required.
Qty 2 - 879981T-XX (in feet for cable length - i.e. -15 is 15 ft) CAN Line cable with built in terminator.
Qty 1 - 878492K14 - 4 port Junction box
Qty 3 - 859318T2 Weather caps for the ports not connected to the gateway.
Recommendation is to mount this at the helm and run the CAN Lines back to the engine.
Parts arrive Monday - I'll post results when I have them.
Today I was told by Mercury I probably also need
84-892323A10 Harness with Diode to go between the Junction Box and the CAN line cable because the Junction box won't know there are 2 engines.
This also means 2 gender benders are required 892453A01
I'll keep posting...
I was able to do it with only these parts:
But do yourself a favour and get the 6 port junction box (878492K16) for the extra few bucks.
The key came down to getting the port engine to know it was port, I offered to setup and configure my dealers software for him using my boat as a test. I'm now his go to Mercury IT tech... doh!
To do that, it was necessary to CUT the 3 power connections on the CAN connector on the port engine (older ones have a multi-engine disconnect). I had to do this because generally people are using the 14 pin connector (round) for digital data - but mine is in use by Rinker for the Analog gauges. Seen in the picture above with the blue/cyan ring. The way I did it is not recommended by Mercury - but once I took the plunge everything started working, the software would not work to change the ID until this was cut.
Now, even with my Axiom panel having a bug not allowing me to identify the engines, the data shows up properly in the devices page anyway for both engines.
I did not get trim data, but this past weekend I found a plug near the transom in a wire bundle which has an analog trim wire connected, replacing that connection with the dangling digital wire as a test got the trim data to the Raymarine too - but not useful there.
Next step ... VesselView 502!
