Rinker 320 Black Water discharge
 Send_Me
                    Member Posts: 9 ✭
Send_Me
                    Member Posts: 9 ✭
                    Good morning folks - I'm new to the site with a new to me 2006 Rinker 320. I've been reading through the threads and am concerned about my black water tank.  I've taken the boat out on a dozen or so day trips and am sure that the ladies have been using the head but my tank still registers as empty.  I'm afraid that there may be a valve open but cant seem to locate it on my boat.  I've looked though the manual but it wasn't much help. Any suggestions?
      Best Answers
            Dream_Inn Member, Moderator Posts: 7,800 mod First thing you should do is open the engine room hatch (make sure the rear door is open first) and then on your port side will be your head tank. You can take a flash light and look at it and see what the level is. The displays don't always read right because they use a float inside the tank to get the reading. The floats can get stuck. I'm guessing your tank is pretty full and need to get a pump out.Dream 'Inn III -- 2008 400 Express
            Dream_Inn Member, Moderator Posts: 7,800 mod I would think the discharge would be in the engine room. Take a look in there at all your seacocks. If one goes to a pump that then leads to the waste tank, that is it. I would think there would be some sort of key switch that would run the pump from the tank though.Dream 'Inn III -- 2008 400 Express
@gack, my boat has an electric head which has a macerator pump on the bottom of the bowel, but no Y valve.
