Engine hatch
terrypage
Member Posts: 165 ✭✭
Any advice, Today pressed the hatch button to raise to check engine etc, but no result, no indication of noise from lift motor, How do I open hatch, any help much appreciated.
https://www.starmarinedepot.com/bomar-molded-inspection-hatch-white-14-x-31.html
Andy
Things that kill an actuator:
Running it to the end of stroke repeatedly (up or down)
Incorrect mounting
Binding at the mounting points
Running at low voltage
Water intruding the motor/gearset/ram
Not greasing the gear drive (if applicable)
In reality, on a hatch lift it is better to mount with the motor at the top. Keeps water out.
