outdrive play
rasbury
Member Posts: 8,847 ✭✭✭✭✭
I have my drive off to replace bellows and lower shift cable. I'm starting to understand a bit how all the stuff turns and tilts a little better. I have the drive off but not the bell housing. As it sits right now, if I grab the housing and lift it up there is little play- if I move it right to left, it moves maybe 1/8 to a 1/4 maybe? Boat has about 300 hours on it so I would not think due for any major redo in this area. What are the two nuts above the bell housing, is there some adjustment for tho to tighten it up? Going to pull up the manual as well...
