Sterndrive lube reservoir sludge
2008 Alpha I outdrive. I drained the drive so I could replace the gear lube as part of my WINTERIZING ritual this week. I noticed about 1/4"of sludge in the bottom of the reservoir. It did not appear to be milky. I tried suctioning it out but I ended up having to flush with solvent. Is this normal? I use Mercruiser HighPerf Gear Lube + only.
Mark
Good, fast, cheap.... pick two.
2019 MTX20 Extreme
2019 MTX20 Extreme
:-D
Mark
2019 MTX20 Extreme
Rinsed mine this past spring. Same amount, talking with some of my "knowledgeable" boating friends
at the marina, very normal after some time.
I just changed mine with the Merc drive oil and cleaned the reservoir. No significant sludge, no metal flecks, no water and the oil looked fairly good for being two seasons old but after about 3hrs of run time on fresh oil my B3 is now starting to sound just a bit noisier than I remember.
When I rinse it on the trailer with the muffs I can hear the normal exhaust tone but it now seems to have a slightly more resonate mechanical sound in the top end that I don't remember before. Might be paranoia but we'll see. Of course it's noisier as it's trimmed up which I avoid. My sterndrive guru can't see it for 10days...bummer as my season is just beginning.
Maybe I'll post a video and let the crew see if they can make anything out. Mike
Thanks, Mike
Already have the ATV lift so here's a simple OD adapter I'll fab tnite to assure it's manageable and done at least annually. I'll move onto a new thread if it needs further discussion. Thanks again.
