Trim tabs
toby11
Member Posts: 4 ✭
I have a 262 BR with 496ho and bravo 3X. What will I gain if anything by adding trim tabs
toby11
Member Posts: 4 ✭
Put 12"x12" Lenco edge mount tabs on my 232 with LED control and it is a different boat getting on plane, staying on plane at lower speed, and in rough water. Also can even out boat when load is offset to one side.
Look at this previous thread;
http://rinkerboats.vanillaforums.com/discussion/946/what-trim-tabs-will-fit-the-transom-of-a-2005-232-captiva#latest. You might need to go up a size for a bigger boat.
If you install them also investigate either the digital switches or a trim tab gauge. I don't have one and wish I did. I'm always second guessing what my tab position is.
http://alturl.com/kcifo
Lotsa $$ for lights. Useful though.
https://www.hodgesmarine.com/Lenco-Led-Indicator-Two-Piece-Tactile-Switch-Kit-p/len15270-001.htm?gclid=CjwKCAjwsqjKBRBtEiwAkWyN3wbeKTPEDJvFzt-dEIUBoFg56emvGMaFv3t_ApZmVyh7UHkEJrr2whoCqmYQAvD_BwE&ppcstrkid=1565162769&click=19&ppcsclkid=MjOhlxRJAvgq&ppcsu=xhg7f5djqeniramsegdoh
I'm 3 hours from the border, but I can tell you that if I ever need something really big like an out-drive, I'll be driving across to get it.
Dave
