Isolator
onislandtime
Member Posts: 309 ✭✭✭
I need some assistance connecting a isolator on my 342. Is it possible that connecting the isolator (incorrectly) could cause damage to the alternator? I will explain now lol. An isolator was installed in my 342 to the starboard engine. The boat was run for 2 hours and the alternator (resistor burned up) failed. Is this just a coincidence???? I have not connected the isolator again until I know this is impossible because the the isolator is suppose to prevent the current traveling both ways, hence the word "isolator" lol. Thanks for any help on this.
So if you hooked the alternator to the output feed you would be back feeding the alternator when the other engine is running.
The isolator prevents other batteries from drawing from the other one when being used . It also allows the one alternator to charge all 3 batteries at once from one output.
Correct your alternator charging terminal should be connected to the input terminal on the isolator . The outputs go to the battery switches. Someownere in between on the input side it gets a feed to the gauge as well but its pretty simply.
If that is the case....That positive wire on the alternator that is now in place is feeding your volt gauge and likely a few other things along the way. You would need to trace that wire and before it reaches the battery.... intercept it and bring it into the isolator first.
Honestly with just 2 batteries its really not needed. Typically when you go up to 3 batteries and dual motors is when they are implemented .
So proper connection of isolator is to intercept the positive wire on the alternator before the battery and connect to isolator?
The isolator is basically a spliter. One signal in, many signals out. So alternator in, charge-to-batteries out.
The isolation part is that a draw on 1 battery is confined to that battery. So if you have a house and a starter, killing the house should not also kill the starter. If you just put the 2 in parallel and have everything draw from them, then you could end up without a way to start the boat.
