Any 270 owners do a battery relocate?
So I'm going to kill two things at once, Moving up to 2, 31 series house batteries(actually all 3 to 31s) , and going to move them to port side to help with constant slight starboard list. Question is, where did you run the cables? Around front of engine, or up and over the back? Anyone have a good place online to buy cables?
Deleted, because I didn't read enough lol!
I have bought cables from this place before. They will put the ends on if you know the length that you need. I have also bought smaller gauge wire in the proper colors.
http://www.ezacdc.com/boat-wiring-products/boat-battery-wiring/
Relocated generator positive cable to port side, next is relocating gen ground cable to port side.
In addition I relocated the battery charger (installed a new one), moved the generator fuel filter/separator, the generator main battery switch, re-routed the fuel and water lines for the generator.
Trying to clean up the messy wiring/hose routing that Rinker does.
Pics will be posted soon.
