I haven't replaced mine yet and this is my 4th season. But I probably should soon, as I have some bubbling back into the head when I flush. No stinky smells though, so it doesn't bother me too much.
Can anyone post what the valve looks like and where it actually is in the flush unit. I have the electric conversion on my jabsco toilet. If it's that easy to change I can just do it next weekend.
It's right where the hose (that goes to the waste tank) meets the toilet. There are 3 or 4 screws and the joker valve is right in there. Just google joker valve or duck bill for a picture (duck bill is same but larger).
Circling back on this. I replaced my joker last June and all was well last summer. Now getting just a slight smell after I flush and wondering if I should replace it again after 1 year. No bubbling at all, just the smell. Holding tank is only at 1/3. We do use it all weekend long, only #1 of course and only biodegradable TP for the admiral. Could this be an annual replacement part?
@Liberty44140 try treating the valve by flushing some mineral oil. Assume you're already putting waster treatment in regularly.
Also, I don't know if waste tank vent hoses have filters on them from the factory. I know my 342 did not have one. I added a Big Orange filter to mine. May want to check and see if you have a filter.
Thanks. Yes I am treating with head treatment, actually if i put a couple of ounces down the bowl the smell goes away for the weekend. I'll try some oil this weekend. I do have an inline vent filter which I re built myself last June with new charcoal, etc. so I'm thinking this is joker or it's just that I need to put some more chemicals down there. Will do the oil though.
That's what I like about this forum - snippets of new information. Next time I am on board I'll check out this little gem of potential olfactory impact.
Mounts inside the discharge hose flange. Back side of the unit at the bottom. Two screws holding the flange to the unit. Second pic is what valve looks like. Called a joker valve as in the shape of a jokers hat.
@icoultha do you have an electric or manual head? @Willhound I have never seen that unit that you posted a pic of in the dozens of Rinkers I have seen. Looks like a neat way to turn a manual head in to an electric head after market? Usually the electric heads have a push button to flush located under the sink. The Joker is just inside of the output hose at the base of the head. Usually 3 screws and a triangular piece.
I have come to the conclusion that I need to replace my joker valve every year. There is nothing worse than coming back to the boat after a week and the head smells like old urine. Ugh... I even flush about a gallon of fresh water when I leave the boat to try and prevent that. The joker valve on my head has two screws. I have seen the aftermarket electric conversion that is pictured above. It isn't the quietest thing, but it might be worth it for the middle of the night flush. One quick twist verses 3 or 4 pumps of the manual flush would probably be better.
That's exactly what it is. Replaces the standard Jabsco twist and lock hand pump. Turn it one way and water comes into the bowl, turn it the other and it sucks it out and pushes it to the tank, also has a macerator in the base to chop up paper etc.
Cool aftermarket upgrade and nice that it's quiet. I like the simplicity of my electric vs vacuflush but yes sometimes at 4am I "let it mello". Greg funny you mention the fresh water flush at the end of the weekend. I always do that to leave for the week, sometimes using leftover bottled water so it's very clean, and just the last two weekends have a smell when I arrive and do the first flush telling me something is secreting in over the week. Sounds Jokerish
If I know I'm going to be away from the boat for a while I'll pour some water in the toilet and pour a little lav treatment in it. When I come back it smells nice and fresh!
Nope. Electric also. Even the one's that are original electric with the pump mounted horizontally to the rear of the bowl. These have three screws as Liberty has pointed out, and probably easier to change as the hose exits to the side instead of the rear. Same joker valve though I believe. Joker valve is $15 to $20 at worst. Something that could/should likely be changed every year or two just for preventative maintenance. I was getting some flow back on our conversion as in my pic above, after changing the valve, works like a champ. Job took 10 minutes. Disposable vinyl gloves and some old rags are your friends....not as smelly, bad a job as you'd think. Edit: Here is a link to the official Xylem you-tube on changing out electric head joker. https://www.youtube.com/watch?v=s2D5Bm_18qE
Checked it out, got the pump model number and thanks to the video, ordered said part. I know I've never changed this so for around $10 a good preventative measure.
may i suggest a petition to swap this valves title with petc0ck valve? I don't mind calling a valve on a heat exchange a joker valve...
