Here we go again... Motor cuts out momentarily, long beep and keeps on truckin..
So lets chat about beeps and such.
383 Mercruiser..
When I turn the key to the "on" position before starting.. I get a Loud 1 or 2 second beep. When moved to the start position, while the motor is starting it makes another 1 second quieter beep. Is that normal? Doesn't matter how long you wait to start it, the smaller beep is there, while the motor is cranking. Could be the depth finder maybe? not sure.
Anyway, the motor has 88 hours on it and wouldn't you know it, I was just thinking how nice it's been to have it be trouble free.... and after running it today, sitting on the hook for 90 mins and coming in...after slowing down for the harbor ride, TWICE in about 5 minutes it "stuttered" going along fine, RPMS Drop, appears to lose power, loud beep like when you turn the key to ON and after that 1 terrifying second is over, it goes back to normal.
I did mess with my vesselview/smartcraft connection today, going to head back down there tomorrow and make sure it's all tight.
Not good before a trip where the boat is your sleeping spot!!
383 Mercruiser..
- Opened up the hatch, looked for anything unusual, did not hear anything out of the ordinary, didn't see anything out of the ordinary.
- I've always gotten a second quieter beep... it's weird that it does it while the engine is still in the middle of starting.. which is why I assumed it might be the depth gauge or something.
Sorry they are so big.. pain to resize them on a mac..
Long way of saying you maybe just sucked up a bit of crud in the fuel. If it happens again, check your filters.
Oh, the other thing we also did was clean up the distributor cap.
@69fastback I ordered this one, https://www.amazon.com/Sierra-MP41040-Ignition-Switch-Acc-Off-Run-Start/dp/B0000AXQN1 - is that good? What'd you get?
I did change my fuel filter and rotor and cap yesterday. The cap and rotor needed it for sure. Although the engine ran better I still got the beep and cut-out a few times coming back off the lake. Why I was concentrating on fuel was because after changing out the filter the first time and running fresh gas, the issue stopped. And then started again. My experience with electrical issues has been that they don't usually solve themselves. Maybe the switch is worn.
@J3ff let us know if the switch does it and I'll do the same.
Either way, no second beep now, re-crimped the wire that needed to be re-done, about 30 mins at low RPM so far so good, then again it's not really a good test as this problem has been pretty hard to nail down... even if it was just a bad wire, I'm happy to change out the switch as it was installed upsidown...and I get a new shiny key..
And...turned motor off.. turned off everything, including blower, went to start it, no second beep... so it must just be a low voltage warning for some reason, I dunno. weird.
