Any Bravo 3 owners ever swap props in water?
Looks like Hill Marine came through and is sending out a pair of 4x4 20p props today... now the question is can it be done in water or do you really have to haul it out? There's a nice flat sandy area to use at anytime to swap them out.. or it's 325 to be put on a lift for a couple hours.. I may just go for the lift so I can do a couple other things at the same time...but if it can be done in water, that'll be tempting.
Doesn't inspire confidence.
I should be able to hit 5200 per here: https://www.mercurymarine.com/en/us/engines/inboard-and-sterndrive/remanufacturing/plus-series-bravo-sterndrives/ (switch it to 383 fwc)
So we'll see what happens, my main goal is to get on plane at a lower RPM and have more bite off the line and have more fine tuning ability, even if the top speed drops a couple MPH that'll be fine. He did say that he's talked to other people with the 383's and for some reason they don't perform how they are expected to at lower RPMs.. we'll see, I make a 270 383 4 blade prop thread for future people..
Warranty expires in Sept, def going to extend it 2 more years.. but if something is going to break, I want it broken now, not later!
ps. today the boat was extremely light, only me on board, had just removed all the heavy stuff below half tank of gas and about 1/2 tank of fresh water, no generator, empty waste tank... which is why 4800 at 35mph isn't exactly impressive especially when the wind and tide was pushing!!
This is the one I bought.
Chris - right now with the 3 blade 22p's I'm cruising at 27mph at 4010rpms. Can't get any worse than that right??
I don't know the history of these propellers that are on the boat right now.. figure we'll start with what the guy says, if I don't like it, we'll swap it out (58 bucks via fedex smart post) and go from there.. but for now, I do know I'm not impressed with the current setup..
was just inspecting last week... still looking good.
