Engine hard starting after fuel filter/water separator change out
2000 FV270 5.7L EFI Gen+
Changed my spin on fuel filter/water separator yesterday as well as distributor cap and rotor.
I didn't have any fresh gas to partially fill the filter when installing, thinking that a bit of cranking would fill it.
After quite a bit of cranking and no start, I pulled the flame arrestor cover and was able to dribble a bit of gas (that I borrowed from a slip neghbour for his generator) down the throttle body throats and got it to fire. A couple more attempts and it fired right up and ran great.
Put everything back together and the boat sat for about 40 minutes while I waited for the Admiral to show up after work. Engine caught on first crank and away we went. Anchored out for about an hour and a half and when we went to leave, had to crank about 10 or 12 times to get start. Tried the throttle in various positions. Once underway, ran great.
Went back to the marina this morning, and same thing. Would start, but only after repeated attempts. Once started, runs like a champ. I don't think the issue is the cap and rotor, I was real careful moving one wire at a time and getting everything back where it was, and it does run great once started.
Did I perhaps create an airlock somewhere by starting with a dry filter? Any chance it'll clear? Is there an air purge anywhere?
I'm thinking now I should have left the filter loose, pulled the coil wire and cranked the engine until the filter filled.
Fuel pump OK?
Mark
2019 MTX20 Extreme
http://www.marineengine.com/boat-forum/showthread.php?388527-350-MPI-wont-start-after-changing-fuel-water-separater
But once I got it running and it ran for over an hour I'm not sure why it's still happening.
good Infos and find on the fuel pump on your posted link.
2019 MTX20 Extreme
http://rinkerboats.vanillaforums.com/discussion/5605/hard-starting-after-day-of-being-anchored/p1
@rinker270nb, interesting thread, but don't know if it applies. Started like a dream before I thought I could improve things with some maintenance.
Wonder if I did somehow throw the timing off a bit when changing out the cap. Don't see how though since it mounts in only one position with 4 screws. Will check the starting battery to be sure but new a few weeks ago.
