Hooking TV up to Shore cable
JOHNR301
Member Posts: 9 ✭
I have 2010 Rinker 360EC. I have a Shakespeare 2020 antenna mounted on my hardtop but I can only receive 4 TV stations.
When I hook up the TV connections on the boat to the shore cable pedestal it doesn't seem to make a difference.
I read that there is supposed to be a switch to change the connections from antenna to shore connections, I searched everywhere but can't find a switch.
Does anybody have any idea where the switch might be located assuming that the 360EC even has a switch.
Post edited by JOHNR301 on
Best Answers
OptionsTonyWalker Member Posts: 744 ✭✭✭
JohnR
In the 342, there is a switch in the cabinet that hosts the TV, along with the many other do dads and wires in there. You may have a splitter in lieu of a switch. I am assuming your 4 channels are in the low channel numbers. It is most likely that you need to find the menu button on your TV clicker and find the menu that has a selection option for cable/over the air service.
Other than that I wouldn't have a clue.
Tony
Salt Shaker 342
Optionsraybo3 Administrator Posts: 5,460 adminI agree with Tony. You would have to run "auto program" on your tv every time you change from "air" to "cable"2002 342 Fiesta Vee PC Point Of Pines YC Revere MA. popyc.org raybo3@live.com
Optionsfrenchship Member Posts: 1,079 ✭✭✭John. On our 300 express the spltter was located hidden in the back of a panel where the power for the T.V. came out. Also on your T.V. you have to choose cable over air in the menu .
OptionsBlack_Diamond Member Posts: 5,439 ✭✭✭✭✭Also, clean the coax wire, the copper lead can corrode and mess up reception.Past owner of a 2003 342FV
