Another Rinker issue
Yesterday while pulling into marina after 45 min ride, warning buzzer goes off continuously. After checking vitals and all are OK, restart engine and still warning buzzer goes off. At idle in slip, same thing. all fluids, temp, oil pressure, etc. OK. what's the scoop?
Read this thread:
http://rinkerboats.vanillaforums.com/discussion/1042/encountering-faults-check-this-out
Great info-Thank you. I have the 5.7EFI with B2 drive. Headed down this morning for a more thorough investigation. I have had Chaparral and about a dozen Sea Rays and some with more years and hours. This one has more issues than all others combined.
it sounds to me like your problem stems from someone not adding/changing the gear oil correctly. When/who was the last time/person to change the gear oil?
as stated above this is not a rinker issue, could be a Mercruise issue, but most likely a user/mechanic issue.
google hive to change gear oil in a bravo out drive and you will see what I am talking about.
for I use quicksilver high performance gear oil 90wt
either way good luck with the repairs.
After drain and fill of gear oil (looked good, no discoloration or smell) and test, still have slippage. Local shop states clutch and gear set (OUCH!). I'm hoping clutch only but may be different upon inspection.
Another issue-serial numbers are worn off label on drive. I have original paperwork from Rinker factory inspection when delivered new and lists engine, hull and other numbers. Says mine is a B3 with duo prop and numbers for both props. definitely a B2 drive.
Calling Rinker to see if they have records that can back into.
