O-rings for fuel fill cap
LaRea
Member, Moderator Posts: 7,992 mod
If you need to replace the o-rings that seal your gas caps, here's a source online:
http://www.theoringstore.com/index.php?main_page=product_info&cPath=367_79_82&products_id=3484
Size: 1-3/4 o.d., 1-1/2 i.d., 1/8 thick (fits most Rinker cruisers)
Material: Viton
I got the size from a thread posted here a couple years ago:
http://rinkerboats.vanillaforums.com/discussion/879/gas-cap
Several people said that Viton is the best material, but nobody posted a source to buy them. I bought six o-rings shipped for ten bucks. If yours are starting to shrink or crack, replace those suckers.
Material: Viton
To make sure that I didn't have any leaks with the new o-rings, I rolled a couple paper towels up and placed them just below and inside the fuel fill hole then placed the caps on "snugly" then took my water hose and ran water for a few minutes, removed the caps and paper towels and made sure of no water intrusion. I also made a small alignment mark on the gas cap / hull to make sure that I properly snug up the caps after refueling.
A friend that has a 2007 320 experienced water in the fuel a couple of seasons ago and it was pretty much a nightmare to get rid of the old fuel and get everything cleaned up. He thought that it was probably due to the original o-rings failing.
For the 342, betting most others too:
.125 (1/8)" cross section
I.D. Is 1.75"
waste/water: .100" cross section. I.D. 1.75"
