Waxing the hill and topside
it's been a few years since I waxed my boat, some slight oxidation present. Can someone lend their opinion on getting the mirror finish back? What wax, or compound and wax to use?
thanks
thanks
then- wax.... and a technique i learned about two weeks ago works very well- it was called "bending it in".
real simple:
with paste wax pad in one hand (i used carnuba) and the buffer in the other at mid speed setting and a finishing pad, wipe the wax on in a small area... BEFORE IT DRIES buff it. if you've done it right you will see the lines of the wax 'bend' as it's being jammed in the pores.... and that's what it's about- making that surface smooth as literal glass by filling the microscopic cracks with wax.... it takes likely five minutes to apply two full coats to a 3'x3' area.
one for the fiber, another for the glass- and the last for vanity. the third coat after buffing the second and allowing it to stand while you work other sections.... this technique is amazing.
after being instructed on this method, I now understand how pro's can do it so quickly with such outstanding results. you don't let the wax stand. you 'bend it in' wet. it defies every instruction i've ever heard prior. it flat out works.
This is assuming you know how to use a buffer the right way also....
I use this as well (& it has ptef in it to give somewhat a nice finish). Mary Kate also has a nice non-skid cleaner. For the swim platform, I sometimes just use barkeeper's friend since runoff doesn't go all over the boat.
http://forums.sbo.sailboatowners.com/showthread.php?t=117266
06 Rinker 270
