320 engine hatch
                    My hatch actuator moves real slow and the last time I used it it would hardly close. It is the original actuator. Has anyone replaced one before and if so what make and size did you use. I have a 2005 320. Thanks
BTW: Acculift is about as cheap as it gets. Very high amp draw compared to others out there.
@Handymans342 - ever filled it out and go a response? I have done about 3 times that in background forwards to email addresses but one bounces. No phone numbers or any other contact so if I don;t fix this the Acculift won't be the replacement based on service and support.
If it keeps pulling out from the mountings, check the sliding sleeve at the attachment point opposite the motor end. The bolt on the sleeve should allow the sleeve to slide to compensate for over retracting.
Better way: get a unit with limit switches. Even better: mount motor end up, keeps water from getting in.
If I have to replace the unit I'll get one of the others instead.
