rinker 2006 "300 cruiser" Acculift Boat Hatch
Does anyone know if i can replace this part with a lenco model or other brand?
Mine make a crazy load noise when opening the hatch or closing and sometimes blows the breaker....
Its time for a new or used one..
Thanks
Thanks
that cracking sound has being happening for 2 - 3 years now
You need the stroke length, speed (inches/min) and rated load to interchange. Should be on the motor label. Prob 500 or 1,000 lbs
BTW: lubing the shaft tube really does nothing.
Warner Linear has solutions and will draw far less current too. Can get limit switches on them too.
http://warnerlinear.com/
After finally getting a contact at QMI that was living and breathing (Andrew St Loius, (519) 7274255, ex 289 astlouis@qmigroup.com ) he was very helpful in providing some guidelines and the key hint to investigation. As @Black_Diamond said, dimension were needed and he sent a form out with photos to log details to send but the light came on when he mentioned where the black tube screws into the cast body. Does this puppy actually unscrew from here, I assumed it was pressed in...? Armed with appropriate tools, down I went Saturday.
I got it to thread on again and drove it up and got all measurements then I popped the actuator out easily - thank god it's pinned in - and laid it out. Lo and behold, with no exceptional force but adequate, the black tube unscrewed from the base and I was able to see easily the problem - the piston had come unscrewed from the top of the lug that travels along the worm. Threaded and tightened and put back together and installed, all is good.
@wielezynski - mine also made similar noises I am assuming that it was due to the looseness of the piston on the travelling lug because she's nice an quiet now. While BD is right in suggesting it may be more than grease, it may not be terminal either. Worth pulling apart.
