yes....i have the flashing hpf ....... ac problem
06 rinker 270 ec.=fresh water lake=temperatures in the 90s=water temp 87=last week=humidity
yesterday==wow beautiful day low 80s=no humidity=same problems
i turn on ac .... it might work a cple cycles or just 1==then flashing hpf=messed with different settings=then back to default/factory==tried pump on/cycle==same= also it will re start after a bit
if i leave thermostat set at just 2 or 3 degrees different=might work better.=78/75
if i drop it down happens faster=78/70
seems to have good flow coming out thru hull..sea strainer is clear
it does get cold=heat does work
i tried backflush from thru hull a cple times
from the expansive ac room under the aft cabin==i can pretzel around and
i hear a grinding sound==not sure pump or strainer.
looks like pump has been changed out=looks like cal pump=maybe some oil on the power cord.
went under with a brush a cple times and scrubbed on the strainer scoop
i removed intake hose maybe medium flow/using a longer phillips head i stuck through hose and immediately got a nice strong stream..re attached ===smile =happy=ahhh job well done
ran ac worked maybe a little better=...dog gone it==same problem.
not much talent here on my end..only what i can read on forum and google.
funny ..no marine ac guys on table rock=the shops say we have a guy that knows some
its a beautiful sunday
thanks to all in advance
not hot like the generator
270 hrs on motor and 70 hrs on generator=no bottom paint. as far as i know and would feel comfortable saying...original marine airr unit...i do not know model or size....going by condition of the boat=the cabin=the head==probably used more as a day boat....or hek mighta had her plugged in and ran ac all the time
no signs of pitting,rust,corrosion,etc any where on boat ...boat is extremely clean and has good service records..just giving a accurately condition report...also i realize brand new items fail.
i know where the return is and cleaned both filters.
i am probably at the end of my =ability/capability
how do i figure out what unit i have ?
on a 270 where is all the other ac stuff====
any 270 owners enlighten me with shortcuts or info==thanks
I'd get real familiar with a voltmeter and the manual, and troubleshoot what you can before you pay a professional. I took mine to the HVAC shop - I knew it wasn't pumping. I paid $50 for the pro to hit it in the specific spot with a 10# sledge. The gauges jumped for a second, then returned to normal. Bad valves. $600 to replace the compressor, or $1600 for the unit. I found a different brand - Marin Aire (notice the spelling), for $1200. Arrived the next day and runs great - at 95° ambient air and 87° water, and high humidity, I was spitting out 45° air.
:-D
i think i went from 250gph to 300gph and it has worked great for a couple of years now
the larger thru hull==black hose coming up = moving towards port ==?
what size/gph is the cal pump ?
thinking of trying some rydlyme flush=
appreciate any help =thoughts=pictures
It's a 6k BTU unit, depending on age it may be 2 different types of refrigerant. 06 is probably R12.
Under the mid-berth sole: Thru Hull -> Strainer -> Pump -> AC
Behind a grate on the mid-berth hull: AC -> thru hull
Hose is 5/8" ID. Pump capacity is between 150-200 GPH.
thanks for everyones help and advice
For someone's
360 ec. We have replaced hose from thruhull to strainer and an new strainer and anew hp switch. All was good for ten days in the blazing Florida heat. Today HPF agin and no water coming out. Cleaned strainer but still hpf blinking. Ideas on what todo next?
