CO Alarm at 1:00 a.m.
ruwallydog
Member Posts: 92 ✭✭
This was a really strange event early this morning. Both CO detectors alarmed about 4 minutes apart in the lower cabin. We reset the detectors ... a few minutes later...they go off again. Not wanting to risk it we packed the kids up and went home. The admiral and I are headed back to the boat today?
The only thing on in the boat was the A/C and a small fan. Any ideas on what could cause them to alarm?
I had all the batteries replaced recently. That's the only variable in the equation that's any different.
Thx
Thx
CO detectors do have a life span too. Usually 5 years then you need to replace. They can be wired in series too, so one sets them all off too.
CO detected is reading 179 ppm on the display.
to be serious. Was the engine or genny on when this happened? Neighbors with genny on? Propane grilling? That number is significant.
Don't underestimate antifreeze, holding tank fumes, etc. I had my home one going off from a leaking geothermal pump, the alcohol based flyid tripped it off.
acetylene, dimethyl sulfide, ethyl alcohol, ethylene, hydrogen cyanide, hydrogen sulfide, isopropyl alcohol, mercaptan, methyl alcohol, propane, nitrogen dioxide, and sulfur dioxide. Isopropyl alcohol - what you use in the stove - is the only false positive we've had on the boat. It wasn't lit - kids just played with the knobs and left it uncapped.
We were able to duplicate the issue again today. Closed up the cabin...only the A/C and portable fan were on....and an hour later we had alarms on three different CO detectors.
I'm leaning towards thinking the detectors are being triggered from fumes from the batteries being charged. That said I'm not 100% certain that's the root cause, but I can confirm that when we activated the blower the CO readings in the cabin returned to normal.
So hopefully once the batteries are fully charged all will return to normal. Hopefully someone on here will have additional thoughts or insight.
Best!!!
Sounds like the batteries are dry/overcharging to emit fumes enough to trigger the CO alarm.
@BlackDiamond. I'm worried about the same...the batteries are sealed so not a water issue, but worried they are overcharging. I'm headed up to the boat tomorrow to take another look. So if that's the case Im thinking I may either have a defective battery or the charger is on its way out. Does that make sense or should I be looking somewhere else?
thx
If they are hot would that point to a bad battery(s) or charger?
