out drive asy
rasbury
Member Posts: 8,740 ✭✭✭✭✭
Will add this to my bellows thread but wanted a quick look at this from the experts! @Alswagg maybe? When I pulled the drive off I read that to disconnect the shift cable from the drive you had to flip up a retainer piece to remove it- when I pulled the drive back, it was already "up" and the drive just came on off without touching anything. I'm concerned about going back together and the cable being secure. The top piece moves up and down freely, does not seem to be broken? Should there be tension on that top piece? Also, looking at the out drive and how it mates to the bell housing, there is a seal that goes around the water pick up tube- where the u joint goes into the u joint bellows I really don't see a seal between the bell housing and the out drive?
The cable will sit in the piece and when you push the outdrive in it will shift to nuetral and the casing will keep the tab down there is no sping load.
Yah the full cooled system dumps in the riser
The 1/2 system dumps under the manifold and up though the riser.
@rasbury , there is a seal for the trim sender wires. I believe there is a bolt up there that is tightened to squish the seal for a tight fit. you can also put some sealant up there with your finger to be sure. In the below link you can see the white "bung" seal.
http://www.mercruiserparts.com/8m0095310-sender-assy-trim-1
sorry i known ur in fl
but u been screwing with this all summer
and found no real answers to ur problem
sometimes it pays for pros to find the problem and do it right
which in return saves u time
and gives u more time on the water
cheers
