Performance data for 2001 270FV with the 496
thepriceisright
Member Posts: 92 ✭✭
I have a sea trial tomorrow of a 2001 270FV with the Mercruiser 496 Mag ****. I can't find any information about this boat with this engine option, so I'm not sure what to expect for top speed and speed/RPM correlation.
Any help is grearly appreciated!
I usually allow 15 seconds to get on plane, but I baby it and bring the RPM up slowly. 6-10 seconds to plane with two souls on board is what I think I read.
Oh, and mines a 280, so a little more beam/similar weight.
- Had the mechanic pull codes. Only the codes that appear when you have a SmartCraft engine not hooked up to any of the external sensors showed up.
- Hours on the ECU were ~33 hours over the hobbs (or whatever boats use...) on the engine cowl (not sure what's up with this).
- The engine sounded amazing. No stumbling or misfires. After several quick drops from WOT to idle I noticed no hesitation or stumbling below idle.
- Full tank of gas, 2.5 guys on board (I'm the fat a** 1.5 guy), it jumped up on plane almost instantly upon applying 3/4 throttle.
- Top speed was between 38 and 40 depending on which direction we were headed.
- The tach registered 4000-4100 RPM at WOT when the engines top RPM is rated for 4600-4999. When adjusting the trim the tach would hop up to 4500 for a second and drop back down. I suspect an issue with the tach, as I don't think we would be doing 27mph at 3000 and then 40mph at 4000.
- The swim platform holds water up while on plane. A blob of water stays under it above the waterline the whole time. I may need to do something about that.
So, overall a great run! Very easy to control even at low speeds, and a brief 45 minutes on the water has me hungry for more! Hoping to pick her up next week!
I'm surprised the top is only 40.. was that gps? If that's the case and your rpm's are low I'd think it's time for a change of props.. especially to the 4 blade ones..
Just fyi, my tach reads 4500, when I'm really only doing 3800, it'll say 5000 when I'm doing 4100... I use vessleview mobile to get the accurate tach readings..
the speed was according to a GPSMAP 235.
Im trying to figure out how best to take advantage of the fact that the engine has a smart craft plug, but there are no other smart craft devices on board. I was considering trying to do the mercury gateway to n2k route to my new display (garmin 742xs), but do you think vesselview is an easier option?
