what do I use?
rasbury
Member Posts: 8,847 ✭✭✭✭✭
I posted this question in the wrong category... had two questions: the grounding wire to the out drive I broke off the head of the bolt trying to get it out as I needed to re paint that area. I will drill and tap a new hole. What do I use to isolate the stainless steel and the aluminum? Also, there was not a bare spot for the wire loop of the ground and the head of the bolt to come into contact with the metal of the outdrive, should there be?
Best Answers
rkinross
Member Posts: 178 ✭✭
I have used seamstick from Saillrite to separate stainless steel shroud brackets from my aluminum mast on my sailboat. Here is the link: http://www.sailrite.com/Seamstick-3-8-for-Canvas-60-Yds - This tape sticks very good to many types of material and should provide a good barrier between the two metals.
rasbury
Heck, this was back from February 2016, don't remember why I posted it!
