Tachometer reading high RPMs, but engine not running hard.
I went out today on my 1999 Fiesta Vee 330 and both tachometers were giving eradicate readings.  I noticed the RPMs were reading much higher for a given throttle position or speed than usual. What gets me is the engine sound did not match the higher reading at all.  At idle, the reading was 2000, yet I can almost guarantee the engine was turning no faster than a normal idle.  While cruising on plane at approximately 23 kts the tachs were reading in excess of 6000 RPMs this is normally in the 3500-4,000 RPM range. While trolling along at approx 8 kts the tachs were reading approx 3200 RPMs, normally this is less than 2000 RPM. At no time did the engines appear to be running as hard as the tachometers were reading. Oil pressure and engine temp read normal.  Any thoughts?
    Those faria gauges are junk. They are definitely not functioning to spec. If this is the first you are noticing than you'll likely get away with a season of just double tapping the tachs and they usually go back to normal. Ultimately You can send them back to be rebuilt. Or go to smartcraft gauges and never worry about finnicky analog gauges again. Or even better vesselview.
    I thought of double tapping my tach, but one shot was enough.
    Andy
    As noted: junk gages.
    x3 goofy gage's mine too
    Mine are crap as well, jumping... and not accurate
  • IanIan Member Posts: 3,064 ✭✭✭✭✭
    May as well add to the list of those with similar experiences with the fine Faria gauges.
  • CoastalGroupCoastalGroup Member Posts: 13 ✭✭
    Thanks, for the input, I will try the tapping to see if that works.
  • scottb3200scottb3200 Member Posts: 46 ✭✭
    I tapped on my rpm gauge for 3 years just ordered a new one
    my starboard rpm gauge just went wonky and reads about 1000 rpms higher. Any solutions to this ? Thanks
    Back of the tach there's a turn dial. If it's on the wrong cylinder setting, it reads wrong. You need to turn it to your setting, I assume V8.
