Leaky port light and moisture in hull
thepriceisright
Member Posts: 92 ✭✭
I just picked up a 2001 FV270. The only place the survey found moisture is on the forward port side port light (see pic). When closed, spray from a hose or spray while on plane will wet the back cushion directly under on the inside.
Any advice on where to start? How concerned should I be with the hull moisture? Should that solve itself once the leak is repaired?
I also removed the windshield screws and rebedded them as well as all the snap studs in the area.
That solved my wet carpet issues.
Re-caulked all around with 4200 leak stopped. I do not think it would be that hard to remove the window, if needed. Oh congratulations, whats the name of your vessel?
