Water coming in somewhere?!?!?!
It's a 2001 340 Fiesta Vee. I have a slow leak coming from somewhere in my boat. I've checked all lines, openings, everything. My bilge pump turns on every other minute and kicks some water out. My mechanics currently have both motors out due to them getting replaced and have put the boat back in a handful of times and still can not find it. Please tell me someone has experienced this before and can help me out.
2001 340 Fiesta Vee 20P Hill Marine and 2 new 6.2 Horizon motors. Whine Down
"My bilge pump turns on every other minute and kicks some water out. My mechanics currently have both motors out due to them getting replaced and have put the boat back in a handful of times and still can not find it."
So how much is kicked out? Is the float just on the edge that it's tripping often? Seems if there's a decent amount of water - not just "trickling down" as noted in another post - it should be easier to find with motors out. Have they closed everything up?
If water is "trickling down" when pulled is it possible it's water going forward from the aft area that is then draining or trickling back by gravity as you pull up the ramp?
if
resistance is present it turns on
i installed one in my old dancer
Through hull or A/C line strainer, or even A/C pump flange leak will always drip if not leak tight, even when the aircon is not running, as they are all below the water line. Please check everything where your through hulls come in for head, and water for aircon. A few drips a second adds up pretty quickly and will turn your bilge pump on regularly.
