spark plugs...standard vs iranium
What's the big difference? Is there a performance reason to go with the more expensive iranium?
Best Answers
F1100 Member Posts: 292 ✭✭✭
iridium last longer, however if you have easy access to the plugs they are a waste. They are used in applications where engine removal is required to change the plugs alot, in automotive engines.
Use standard plugs, gap them correct and use the correct heat range and you will be golden.
1993 300 FIESTA VEE TWIN 5.7L ALPHA GEN 2 -
reneechris14 Member Posts: 3,134 ✭✭✭✭✭
@skennelly Iridium is a very hard metal or mineral found on the periodical scale in science class. As far spark plugs go they last for ever. 500 hrs for me would be 10 year's see that's for ever.2005 Rinker FV342 Pawcatuck river,Ct
http://ww2.justanswer.com/uploads/ROCKETBOAT/2008-12-09_042519_SPARK.pdf
I guess that's my real question here
I see the 350mag now recommends NGK ITR4A15
06 Rinker 270
