trim sensors
rasbury
Member Posts: 8,855 ✭✭✭✭✭
Putting my drive back together and re installed my trim sensors....they were indented where they were installed before and I did not move the little rotating things on the sensor them selves. So, I did look in the manual and see the marks to align the sensors with and moved the port one slightly to align- the starboard one I'm not seeing a mark on the male side of the sensor. Since nothing moved, I thought at the least they would be close and I would dial them both in as the manual states. So, when I put them on the gauge at the dash is full up, drive is down. So, I pulled off the port side and rotated in 180 to see if it changed it and nothing. Now that I think about it, that side is the limit side of it and probably should have done that to the starboard side but - if nothing "changed" should it not have show down as I had left it when I took everything apart? What am I missing??
Best Answer
rasbury
Duh....didn't think about that! Thanks for the common sense answer @Alswagg . I hope a moderator can pull these random couple of threads onto the bellows thread...so I will play around with that....the gauge would have been full down when I took it apart- gauge is pegged full up- not a worry?
