electric outlet
we also can not use the electric outlet even when the boat was plug in dock, or when the generator is on in the water. there is a brake in the generator panel that says electric outlet, we put this in on, and we never receive the energy.
Is it a ground fault outlet? If so, the thing has probably tripped. In that case, all you would have to do is push the reset button, located on the outlet itself.
Tony
Salt Shaker 342
I'm assuming on your 110V breaker board (should be close to your galley) that you are powering on either the shore power or generator? The board should be close to your galley in your cabin.
Please be careful with this switch, if you don't follow the right procedure you can damage your boat, and even worse harm someone.
