Fresh water system
we where not able to make work the water system, we fill the water tank with fresh water, but the sink the one that is in the main cabin and the one down never work,also the one inside the lavatory. the toilet works perfect.
- Welcome to the forum
- What year and model is your Rinker? (we're guessing without that)
- A manual toilet probably fills/flushes with seawater. Is the fresh water pump motor running when you open a sink valve?
- If not, is the dash switch on and is there 12v at the pump. Check the breaker too.
If the pump runs but no water then look for a valve/ shutoff/ disconnected line
That's all I have. Good luck and let us know what you find. MikeDream 'Inn III -- 2008 400 Express
funny to see a 2013 post back up and TikiHut’s name!
