111
13»
  • seguirseguir Member Posts: 170 ✭✭✭
    Again Thank you both and to all that may have commented....All this is great info!
    It may be shy of horsepower, but I bet the torque and the torque curve is mucho stronger... Torque is truly where it's at.
    Hey Seguir, It's good news that you have the 350 mag. In my opinion it is quite a bit stronger than a stock 5.7. I do not agree with your dealer that 20 HP tells the whole story as the 6.2s are mini torque monsters - they pull (and REAL hard) all the way from o to wot. Yes, I would  have liked to have seen an 8.1 in your boat but, again in my opinion, your 350 will be fine if you look after it oil wise. Having a tech you trust look at your 350 mag when you haul out is still a good idea. In the meantime please don't lose sleep - I think what is happening just might be normal for the way your rig is set-up. Hey Drew - no matter what the topic I always enjoy, appreciate and LEARN from your comments! As we all know our product is helping each other but our strength is our numbers! Regards to all! MT
    Drew, but hold on, if he's reaching 4000 rpm, he should be pushing X amount of water over the props. Which means, he should be reaching 30 mph, provided load or drag hasn't changed. Right?
    Yeah, but this is about to get tricky... Check it:
    The engine doesn't limit the output based on load (as measured by vacuum signal) but on revolutions.. it will NOT rev beyond 5400 even in neutral. The engine in neutral could likely nail the limiter at half throttle. The engine in gear and pushing the weight likely isn't capable of nailing the limiter.. at 4800rpm, that engine is likely nearing or at full throttle, and to the point if it was capable of producing proper power it would be revving beyond 6kRPM, or in neutral without a limiter nearing the mechanical maximum (if it was stupid balanced and valve train could handle it, that would be at or near 12kRPM, but there are only a handful of carefully crafted v8's that can handle that)...
    The 4800rpm he can nail is not producing the power it should be at 4800rpm, because the air to fuel ratio is all buggered up- its trying to rev more but it can't due to load. You'd be wanting an easy 5k on a magnum which produces power, which means anything under that is property trimmed (fuel trimmed, not hull trimmed), and the engine isn't struggling, and is producing the expected power a proper fuel ratio gives... He may be dumping 20% more fuel than an identically loaded and duplicately equipped boat running alongside him, working harder, and producing less power. Oh, and burning more oil to boot..
    In a shorter response: his horsepower is there (work), but his torque isn't (sustainability of work or difficulty to stop it from spinning)... Or, maybe the torque IS there, but its being spent in slip instead of bite..
    I'd be curious to see the outdrive gears teeth.... I'd also be curious to see the props blades.. I ain't gonna get hung up on those, though, because if they we slipping, revving wouldn't be a problem, slipping would be, and it wouldn't have slipped all season (or since the birth of this thread) without the gear box grenading, or such unbalance he'd have looked at the prop by now..
    And about the speed: more of his hull could be displacing instead of riding due to loss of power. Those calculators, which I dig, fall flat on that regard.
    In cars: forward speed, overall gear ratio, and rpm are written in stone.. if you know two, you can determine the other.. on boats, the overall gear ratio has a variable almost impossible to standardize, which is displacement of water, and manifest in slip by most calculators, but doesn't account for slippage based on the boats attitude, or planing surface, which whittle at speed and increase load... Load is the great unknown, and THE thing to manage when tuning an engine and pairing an engine to an application... Thats why big blocks rock in boats. :-)
    I'm on a mobile device and editing is difficult... I don't thin I've explained myself well... Let me hit it this way:
    An engine capable of producing the power will be limited only by safety margin of maximum revolutions before it flies apart.. that's why rev limiters exist.. they won't let you float the valves...
    An engine capable of pushing a load up to the limiter is wasting capacity.
    A prop may be too steeply pitched which puts too much load on an engine and limits its revs while it allows slipping at the same time... Where as a shorter pitch will allow the prop to spin up and slip because there is too little load on the engine due to leverage... A proper balance of power and pitch to load ratio will allow the engine to reach its maximum sustained load index, and limit slip. He seems to be properly propped if it is an OE prop selection from the factory, he's just slipping it because he doesn't have the proper power at an rpm to push the boat further out of the water, promoting slip and not decreasing load as expected if there was less boat displacing...
    If he planed more hull, the load decreases, which allows more power translation to screwing water as opposed to pushing it, which equates to less slipping as it bites..
    This is same concept as to why a dirty hull won't allow rpms or speed.. its loading the engine AND its promoting slip.
    Sometimes we just think too hard but I believe I mentioned it might just be poor trim in an unfamiliar boat, and could be magnified by a load balance issue which these larger single engine boats can easily fall prey to......
    Has anybody asked about the condition of the bottom? Even a little slime/crust can/will kill performance.
    Maybe take an experienced marine mech/pilot friend for a ride who can conclusively say it needs more/less throttle/drive angle/speed to get fully on step at an efficient speed and then carefully find (and note) the sweetest trim settings at cruising speed(near 26mph). Our 270 with a perfectly clean bottom, OD trimmed slightly up/aft from parallel to the keel and no tabs is happiest at 3800rpm and 26-27mph.
    21mph is NOT on step. 4k rpm should be very near 26-30mph.
    If it's not that simple (sure hope it is) then there's plenty of detailed possibilities elsewhere in this thread.
    Good luck. Mike
    We have very nearly the same boat and here's what a well trimmed 26mph looks like fully loaded full of fuel/water and with 4 souls on-board....
    TikiHut2 - The bottom has never been painted and does have some growth.  Your Picture is what I have with NO TRIM TABS  on plane doing 20 to 22.5 MPH (GPS readings) between 4000 to 4200 RPM's. I have played with the trim on the drive to maximize my speed.   I notice it doesn't take much to trim it up after I am on plane. Michael T statements make the most sense...but will still do some investigation once the boat is out of the water. Eg: engine, outdrive, and prop.
     It is worthwhile to note when I use the trim tabs when I am on plane My speed is reduced.  I only now  use my trim tabs to help go on plane and/or to balance my boat when people move around.  At time I needed them when water conditions warranted them to balance again to balance the boat.
    edited September 2013
    From my experience trim tabs only help get onto plane easier/quicker, but it does not change the speed you get onto plane. On my boat no matter where my trim tabs are if I'm above 21 mph I am on plane, that simple. And when I'm on plane that speed corresponds with an rpm of 3600. The only time that changes is if I'm in a major chop that being over 3 ft waves. If I am at 4000 rpm, I am running at 30 mph plus or minus 3mph depending on where my trim tabs are.
    I know every boat is different, but my 276 really likes 2 "dots" of trim tabs even in perfect water/wind/weight conditions. It keeps the bow from pointing too high and is worth probably 2mph at the same rpm as with no tabs. It definitely keeps the boat nice & level too.
    I wish more people would post up graphs of speed (gps), rpm, and fuel burn for each style boat. I think it'd help alot of people when they arent sure if their boat isnt running how it "should". This weekend should be near perfect conditions up here, so I'm planning on getting a bunch of speed & corresponding rpm readings.
    2013 276 Cuddy ~ 350 MAG / B3
