Trim Tabs Not Working - electrical question too
New Rinker 342 owner here. I just got my boat and trying to figure out what electrical powers what so this may be some switch or something I'm doing wrong. My Trim Tabs seem to not be moving. The lights work on the helm and the are not even. the lights don't move when I push the up/down buttons? Anything I need to have switched on for them to work? Any ideas as to the problem? In addition when running my Gen Set and switching on everything in the control panel the Air, microwave, and coffee maker are not working. Left voltage meeter isn't showing anything but right one is?? Sorry for the stupid questions, brand new at this.
Assuming they are electric, you can trace the wires at both ends. It could be a simple lose or broken connection. Lose ground connection is a very common cause of electrical problems.
Welcome aboard and congrats on the 342. We just finished our 4th season with ours and love her.
http://rinkerboats.vanillaforums.com/discussion/5793/rinker-frequently-asked-questions-faq#latest
Think for the genny ? You need to switch the main breaker.
Welcome to form and congrats on the 342. Just finished my 1st full season.
The black box with all the wires is the brain. It has one connector that goes to the actual switch. Then one you wire into power and ground. Power should be switched so that it comes on when you turn the key. Then the other two are to your trim tabs. Just remember before you close it all up to test. Moving the Right switch should move your left trim tab. If it doesn't just swap. The switch instructions say that if you cut the wires you void the warranty. I ignored that. This is a really helpful upgrade. 1. I always know the tab positions and 2. they reset back to full up when i turn off the engines. Love that.
