Turn key = no start ?
So i went to start the engines today, it's been a few weeks, port fired up perfectly as usual, but no such look on the starboard. The starter appeared to spin just fine while the key was turned but it was not engaging. So i assume power to the starter is fine. If I recall most starters have a little gear that pops up to engage the flywheel and crank the motor over. It sounds like that gear is not engaging but rather just spinning below the flywheel.
So what say you guys? Do you think bad starter, bad starter solenoid, or something else? Anyone change one before? I hear access is a real pita. It's my starboard 496.
Yep that starter is not fun to get to. I would have either been pulling all my batteries and water heater, or removing the manifold. Still a pita to even do wire work.
An easy test my marina mechanic showed me was a piece of wire with alligator clips running from battery to coil. When the boat started he said "It could be a few other connections, but I'll bet dollars to donuts it's the orange wire". He was correct. Mine hadn't worn through, but it had a built in fuse holder and the connection to the fuse was loose.
i ran into an engine that laid just outside the mounting blocks, and disallowed two of the four bolts to come out of the starter... this is before i had a gantry making engine lifting easy... i unscrewed them, cut them off, let them drop to the block again and cut them once more... those two bolts came out in six pieces.
swapped the starter- used the two bolts that fit in/out fine to hold it in place, and found a bolt that allowed a couple threads to reach the tap and added some blue loctite to it, and forwent the fourth bolt altogether... i always meant to go back and fix it 'out of season' or if it caused any issue..... but it never did. not sayin' this is right and it's something i usually wouldn't do or condone- but............. sometimes, though rare, it is advantageous to leverage over-engineering in your favor.
