Lost power to Engine hatch, Bilge pump,Galley pump and Engine room blower
Hi.
Just sudden the above stopped working at the same time.
I have checked the fuses under steering helm (i guess these pop out if they have some problems?)
Also checked the power breaker at the DC panel. The one for "Helm power" is working, as by tuning this on/off the other functions on the switchboard is affected.
Anyone with any ideas? Seems strange to me that all these 4 things went out at the same time.
I'm going to have to document where everything goes now, as it doesn't match the electrical sources supplied by the manufacturer. Crap.
i have already checked everything in the engine room without any findings... all 3 batteries are at 12.5V so should not be battery related, since every other electical installation is working perfect.
Could some of the electric components just be hooked up to one of the house batteries, and the rest to the other battery? I thought "everything" was working together with both batteries (?)
Appreciate all your help.
http://rinkerboats.vanillaforums.com/discussion/3038/280-ec-wiring-diagram
Season is nearing, and I need to sort this problem.
I have removed the main breaker panel and all looks good, even loosened every connector and re-tightened it to ensure good connection.
since me+Wire diagrams are complete enemies, it has not shed any light on where the problem is located.
Can anyone check what the main breaker labeled "Steering Helm" actually does? I have tripped it to see what stops working, but other than the things mentioned earlier, everything is working despite that breaker is tripped/unconnected.
I have a Volt Meter.
there is Power to both the button/switch for eng hatch along with the small breaker for hatch under the steering helm.
so seems like it's a bad connection between the breaker at the helm and the actual hatch motor.
same goes for the Blower switch and water pump.
I have also checked grounds at the aft "wall" in engine bay, all are good. Is there any other places where stuff are grounded? (already taken out the landpower/fuse cabinet inside the boat, all looks good...
Any idea where to find this connector/connection (connector 10) point?
connector in the middle of the picture had come apart just enough that it had no connection.
All is working
While underway yesterday lost power to Raymarine multifunction display (chart/radar), nav lights, vhf, horn, arch lights, floor lights, transom light. Also no power to main blower or engine hatch.
Batteries are new this year. VV display still works as do all engine functions (Axius, etc.). Checked every available breaker - nothing unusual found.
I have a feeling it's a multi-pin connector that may be loose somewhere?
Anyone have a 2014 310 EC diagram to see if all these route through same bundle/connector? Or where to look to troubleshoot some more?
The VV is powered by the DTS circuit, so it would not be affected.
Of course, yours is wired totally different from mine, so I might be off-target here.
